Dynamics Ax 2009 Reporting Tools and Visual Studio 2010 Compatibility
Is there any way to install the reporting tools in VS 2010? The documentation says VS2010 will work with AX 2009 if it is run side by side with VS 2008 but I can’t get the tools installed in VS2010. Any help would be appreciated! Thanks!
If you are using Ax 2009 I advice you to use VS 2008, as far as I know reporting tool don’t work with VS 2010.
Fabricio is right.
Only Visual Studio 2008 works with AX 2009 Reporting tools. I understand this is because of incompatibility.
Thanks guys! I was pretty sure that was going to be the answer but was hoping someone had figured out a way to make it work.
