I am investigating the possibility of using stoarge by chaos (just put the finished goods wherever you want, wherever a free space may be) in an AX2009 WMS I system.
Right now, whenever you make a quotation in AX, create a PO in AX, etc, the warehouse dimensions are filled in for each items you select with the site specifif order settings.
The problem is that the warehouse location can change right after creating the order if the employee decides to put the goods in an other, better suitable place. The order still points to the old location.
One solution can be to work with common locations, like ‘picking-01-01’, but every demand will then be at picking-01-01 and you have to transfer the goods every time from the rack location to the picking location first and then to the right place.
After some Googling it seems like dynamic slotting isn’t possible in AX2009. Can someone inform me about this?
Maybe we have to throw the idea overboard because it’s not possible?
