In my AX Test Server event viewer, I am getting the following error :
Event 4000 , Dynamics Server 01Duplicate request to load user role mappings detected.
Did anyone faced similar issue.
Any preferred solution.
regards
Under event viewer following error it shows :
Note: Only for CFO, I have added a user under user profile.
Is it causing any problem?
Not experienced!
Then I wouldn’t spend time investigating it. You can create a support ticket with Microsoft, though, if you want some statement from them.
Thanks Mr. Martin,
My concern is that since it is not a Warning that can be neglected.
Anyways will check.
regards
