Dual write data not passing
I have successfully started dual write in a vm. The dual write in the system was working ~ 10 days back, now when I have started it it is running successfully for several entities but when I try to update/ insert any record in UI which is part of the entity I do not see any records in CDS. I have tried using different filters etc in the target but this issue is persisting. Can anyone please provide me any pointer on how to resolve this issue?
Thanks in advance!
The general response from Microsoft would be to stop the maps, de-link the systems, check that the F&O - DualWriteProjectConfiguration, DualWriteProjectFieldConfiguration, BusinessEventsDefinition and CDS - DualwriteRuntimeConfiguration tables are all empty. Then rebuild the system.
You dont mention what you are synching, so it is a generic answer. Are you sure the original initial sync passed records and now it is not?
