Dear All,
I am new AX .I have two drop down.
DropDown A has 2 values - Onsite and Offshore
Dropdown B has list of projects from the project table where it has a check box stating yes or no or (1 or 0)
In my form i need to select the dropdown A with the type onsite .Then the dropdown B should populate all the projects which is related to 1 which type field from the proj table
If the user selectes dropdown A as offshore then the dropdown b should populate the projects which is related to the type field of 0 from the pro table.
So i need to populate the dropdown B in accordance with the dropdown A selection
Please let me know if my explanation is not clear.
