Hi guys! We need to do a drop ship between Canada and USA ( 2 companies in the same database)/ The supplier is located in Canada and the customer is located in USA. These are steps: 1. The Customer ( located in USA) order goods from Vancouver location ( located in Canada) 2. Vancouver must buy goods from the supplier ( located in Canada ) who then send them to the customer. What is the best way to handle that in navision 3.6 without any major customisation?? Thanks
Hi Tatiana Essentially this is intercompany transacting/processing, and all the ramifications this brings with it, which I believe has been talked about previously in this forum. I think it can be done, but with customisation or the use of BizTalk server[?], but if you want it without this I think hte answer would be to do it the old fashioned way, manually [:D]
