doubt on scrap
There is a column called scrap% in firm planned PO
And scrap quantity in O/P journal.
What is the difference between these two fields and where do we use them
This calculates the quantity for calculating components if in BOM ur quantity is 10 for RM and scrap % is 10 after refreshing the production order the line components will show req as 11, this comes from Item Card.
Scrap on output filed is meant for just mentioning the item which cannot be used, this is always filled manually.
