doubt on license
My license permits report, table,form, dataport and xml designer and also i have application objects - code units (100) but when iam trying to design a form C/Al code is not getting displayed. also iam unable to crete or open the existing code unit.
But C/Al Code is getting displayed in reports but iam not getting in forms.
What is the problem.
Your license has to contain granule 7200 (Application Builder) for you to be able to work with codeunits and “behind” forms.
Hi Michael
Are you a partner or an end user. If you are a partner I suggest you download the price list explanation, if you are an end user I suggest you talk to your partner and get them to explain what you have actually bought.
I presume you have access to 7120 (7150 BE), this is the form designer - this granule DOES NOT give you access to the CAL from form or pages. This is true of 7130 for Table design as well.
Your confusion is that 7110 Report and Dataport designer DOES give you access to the CAL code.
To gain access to the CAL code you will need 7200 Application Builder or 7300 Solution Developer depending upon your requirements.
thank u adam u r rite i dont have solution and application builders.
