How can i “POST” a sales journal using NAV webservice.
you have to create a webservice whcih will call all the codeunits and tables related with journal posting routines in naviion also be careful about all the error logs occuring in between the process of posting.
Kindly provide more details which sales journal u want to post.
Here is some of the code , the function is “postsalesjournal”
<?php include('credentials.inc'); include('NTLMStream.php'); include('NTLMSoapClient.php'); class Navcompany { var $Navservice ; var $CustomerPage ; var $CustomerStatement ;// url var $Salesjournal ; //url var $chartofaccounts ; //url var $Accounts; // variable Var $No ; // variable Var $Name ; // variable Var $Balance_LCY ; // variable var $LastPayment_LCY ; // variable Var $Address; // variable Var $Soapobject; var $Postingdate; // variable var $Glaccountno; // variable var $BillAmount=0; // variable var $Comment; // variable var $NavDate=0; function postsalesjournal(){ if(isset($this->Salesjournal)){ // we unregister the current HTTP wrapper stream_wrapper_unregister('http'); // we register the new HTTP wrapper stream_wrapper_register('http','NTLMStream') or die("Failed to register protocol"); try{ $service = new NTLMSoapClient($this->Salesjournal); } catch (NTLMSoapClient $e) { prnMsg($e->getMessage()); } $mydate = $this->uptodate($this->Postingdate); // Create object $create = new stdClass(); $sq = new stdClass(); $update = new stdClass(); // Add Sales Quote to Create $create->Salesjournal = $sq; $create->CurrentJnlBatchName="DEFAULT"; $result = $service->create($create); // Retrieve record key to use in update request $key = $result->Salesjournal->Key; $sq->Key = $key; $sq->Document_Date = $mydate; $sq->Document_Type = 'Invoice'; $sq->Account_Type = 'Customer'; $sq->Account_No = $this->No; $sq->Amount = $this->BillAmount; $sq->Bal_Account_Type = 'G_L_Account'; $sq->Bal_Account_No = $this->Glaccountno; $sq->Description = $this->Comment; $update->Salesjournal = $sq ; $update->CurrentJnlBatchName="DEFAULT"; $record=$service->Update($update); return $record; } } function chartofaccounts (){ //Income_Balance//Income_Statement if(isset($this->chartofaccounts)){ $params = array('filter' => array( array('Field' => 'Gen_Posting_Type','Criteria' => 'Sale'), array('Field' => 'Account_Type','Criteria' => 'Posting'), array('Field' => 'Income_Balance','Criteria' => 'Income_Statement'), array('Field' => 'Direct_Posting','Criteria' => 'Yes')), 'setSize' => 0); // we unregister the current HTTP wrapper stream_wrapper_unregister('http'); // we register the new HTTP wrapper stream_wrapper_register('http','NTLMStream') or die("Failed to register protocol"); try{ $Page = new NTLMSoapClient($this->chartofaccounts); } catch (NTLMSoapClient $e) { prnMsg($e->getMessage()); } $result = $Page->ReadMultiple($params); $this->Accounts= $result->ReadMultiple_Result->chartofaccounts; } } function showcustomerdetails(){ if(isset($this->CustomerPage)){ // we unregister the current HTTP wrapper stream_wrapper_unregister('http'); // we register the new HTTP wrapper stream_wrapper_register('http','NTLMStream') or die("Failed to register protocol"); try{ $page = new NTLMSoapClient($this->CustomerPage); } catch (SoapFault $e) { prnMsg($e->getMessage()); } $params = array('No' =>$this->No); $result = $page->Read($params); $customer = $result->Customer; $this->Name = $customer->Name; $this->Balance_LCY = $customer->Balance_LCY; } } function getcustomerstatemnt(){ $this->Balance_LCY=0; // we unregister the current HTTP wrapper stream_wrapper_unregister('http'); // we register the new HTTP wrapper stream_wrapper_register('http','NTLMStream') or die("Failed to register protocol"); $f = $this->uptodate($this->Postingdate); $this->CustomerStatement = baseURL.rawurlencode($_SESSION['SelectednavCompany']).'/Page/CustomerLedger'; if(isset($this->CustomerStatement)){ $params = array('filter' => array( array('Field' =>'Customer_No','Criteria'=>$this->No) ), 'setSize' => 0); try{ $Page = new NTLMSoapClient($this->CustomerStatement); } catch (SoapFault $e) { prnMsg($e->getMessage()); } $result = $Page->ReadMultiple($params); $entries = $result->ReadMultiple_Result->CustomerLedger; if(is_array($entries)){ foreach ($entries as $amount) { // $this->Balance_LCY += $amount->Amount_LCY; $this->datediff($amount->Posting_Date, $f, $amount->Amount_LCY); } } else { // $this->Balance_LCY += $entries->Amount_LCY; $this->datediff($entries->Posting_Date, $f, $entries->Amount_LCY); } } return $this->Balance_LCY; } function getlastpayment(){ $this->LastPayment_LCY=0; // we unregister the current HTTP wrapper stream_wrapper_unregister('http'); // we register the new HTTP wrapper stream_wrapper_register('http','NTLMStream') or die("Failed to register protocol"); $t = $this->fromdate($this->Postingdate); $this->CustomerStatement = baseURL.rawurlencode($_SESSION['SelectednavCompany']).'/Page/CustomerLedger'; if(isset($this->CustomerStatement)){ // '2016-01-10' works $params = array('filter' => array( Array('Field' =>'Document_Type','Criteria'=>'Payment'), array('Field' =>'Customer_No','Criteria'=>$this->No)), 'setSize' =>0); try{ $Page = new NTLMSoapClient($this->CustomerStatement); } catch (SoapFault $e) { prnMsg($e->getMessage()); } $result = $Page->ReadMultiple($params); $entries = $result->ReadMultiple_Result->CustomerLedger; if(is_array($entries)){ foreach ($entries as $amount) { // $this->LastPayment_LCY += $amount->Amount_LCY; $this->date2diff($f,$amount->Posting_Date,$amount->Amount_LCY); } } else { // $this->LastPayment_LCY += $entries->Amount_LCY; $this->date2diff($f,$entries->Posting_Date,$entries->Amount_LCY); } } return $this->LastPayment_LCY; } function __construct($show=null){ // we unregister the current HTTP wrapper stream_wrapper_unregister('http'); // we register the new HTTP wrapper stream_wrapper_register('http','NTLMStream') or die("Failed to register protocol"); try { $this->Navservice = new NTLMSoapClient(baseURL.'SystemService'); } catch (NTLMSoapClient $e) { prnMsg($e->getMessage()); } if(Isset($_POST['company'])){ $_SESSION['SelectednavCompany']=$_POST['company']; } if($_SESSION['SelectednavCompany']) { //SalesPost $this->SalesPostCodeUnit = baseURL.rawurlencode($_SESSION['SelectednavCompany']).'/Codeunit/SalesPost'; $this->CustomerPage = baseURL.rawurlencode($_SESSION['SelectednavCompany']).'/Page/Customer'; $this->CustomerStatement = baseURL.rawurlencode($_SESSION['SelectednavCompany']).'/Page/CustomerLedger'; $this->Salesjournal = baseURL.rawurlencode($_SESSION['SelectednavCompany']).'/Page/Salesjournal'; $this->chartofaccounts = baseURL.rawurlencode($_SESSION['SelectednavCompany']).'/Page/chartofaccounts'; } if(!isset($show)){ echo ''; echo ''; echo ''; if(isset($_SESSION['SelectednavCompany'])){ echo ''; } echo ''; echo '(Selected) Company Active:'.$_SESSION['SelectednavCompany'].' | |
'; // Find the first Company in the Companies $result = $this->Navservice->Companies(); $companies = $result->return_value; if (is_array($companies)) { foreach($companies as $company) { echo "". $company .""; } } else { echo "". $companies .""; } echo ' |
'.$days.'DateDiff='.$this->Balance_LCY; return $this->Balance_LCY ; } function date2diff($date1,$date2,$Balance_LCY){ $x = strtotime($date1); $y = strtotime($date2); $str = ($x - $y) ; $days = floor($str/3600/24); if($days>0){ $this->LastPayment_LCY += $Balance_LCY; } // echo '
'.$days.'Date2Diff='.$this->LastPayment_LCY; return $this->LastPayment_LCY ; } } ?>
for calling nav web services via php best you follow
blogs.msdn.microsoft.com/…/
http://www.dynamics.is/?p=390
dynamicsuser.net/…/69232
blog.artea.info/…/
