hi all
i am trying to create a general journal from c#.net
for tat i written my code in .net, i added necessary classes and reference in my .net project too
but whn i initialize the values in container am getting error msg as
acctPattern = [‘211345-Disp’,‘211345’, 2, ‘Department’,‘00000014’,‘CostCenter’, ‘00000007’];
Error 7 Invalid expression term
Error 5 Too many characters in character literal
pls suggest me some ideas,
thanx in advance
C# uses single quotes for character literals. Use double quotes ("") for strings.
Please ask development-related questions in the developer forum. (Moved from the Technical forum.)
hi martin,
after changing also got same error…
acctPattern = [“211345-Disp”,"211345’, 2, “Department”,“00000014”,“CostCenter”, “00000007”];
thank you…
If you used your time for reading your code and listening to the compiler instead of immediately going to this forum, you would have noticed that you didn’t replace all single quotes.
hi martin,
pls chk the above screen shot, now its corrected.
still same error
No, it’s not the same error at all! Now the compiler says that [ can’t be used where you’re trying to use it.
C# is a different language than X++ and it doesn’t have containers like X++. It has arrays and other collection classes, such as dictionaries.
Please learn basics of the language before writing any code.
