i get in error in loadfile
have you any idea to resolve this error?
No, unfortunately we can’t help you if you don’t tell us what error you get and where.
Hi martin ok you are right
the error in DmfStagingWriter.compresscopyfile()
public server static boolean compressCopyFile(str _fileName, str _newFileName, boolean _overwrite = false)
BinData binData;
BinData bCopy = new BinData();
container c;
int s, offset, pSize = 30000;
if (winapiserver::fileExists(_fileName))
binData = new BinData();
binData.loadFile(_fileName);
binData.compressLZ77(15);
s = binData.size();
while (offset < s)
if ((s-offset) > pSize)
bCopy.copyData(binData,offset,pSize);
offset += pSize;
else
bCopy.copyData(binData,offset,(s-offset));
offset += s-offset;
c = bCopy.getData();
DMFStagingWriter::decompressWriteFile(c,_newFileName, (offset == s) );
return true;
What error do you get and at which line? What you’re doing when you get the error? Did it work before and if so, what has changed since then?
Also, please use Insert > Insert Code to paste source code. It’ll preserve indentation.
