Disposition Code issue in Quality Order - Ax 2012 R2 CU1
In Quality Order, the test result is fail, based on that disposition code is updated in quality order form header level.
after that validated quality order and the status is showing fail. but as per the disposition code setup system should not allow to issue the material any where ( Sales issue, Production Issue). currently system is allowing to issue the material for consumption.
even the disposition code is not updated in quarantine order and on hand inventory form.
quality order has been crated from quarantine order.
any one can explain the solution.
did i missed any setup.
please do the needful.
