Hi Everybody, I’ve a employee lookup,which displays both the employee id and employee name, I want to display “EMPLOYEE NAME” in the field,when i select the employee id from the lookup. Is there any way to do this…please help **I want to display the name wherever i select the employee from lookup thourghout AX Please Help. -Regards, Rajee
Use edit method for lookup.
Hai
You can override modfied field in table level/form level of empl id field.
OR display method for employe name based on emplid.
Regards
Shon
Use the following code on your table
edit Name Name(boolean set,EmplId val)
if (set)
if (!val)
warning(“Error”);
else
this.EmplId = val;
return EmplTable::find(this.EmplId).name();
use this method as a control for form in place of emplId field control.and override lookup method for this control by following code
public void lookup()
Args args;
FormRun formRun;
args = new Args();
args.name(formstr(MIN_EmplLookUpId));//MIN_EmplLookUpId will be your lookup form.
args.caller(this);
formRun = classfactory.formRunClass(args);
formRun.init();
this.performFormLookup(formRun);
Hope this will work as solution.
