Can you help me, Im new to reporting in NAV how can i display the user profile of the current user accessing the report
e.g
User ID: Bong Arevalo
Profile ID: Accounting Manager
Hope to hear from all of you soon, thanks
e.g
Hi Pong,
Could you please mention the version of your nav so that we can able to let u know…
its Navision 2013
For the USER ID you can use built-in [User ID] field (if you open report [Layout], under [Report Data] there is a section [Built-in Fields] - just drag the field to the section, where you need it.
For Profile ID you will have to add a new data item “User Personalization” in report designer and add the column with [“Profile ID”] field from this table (remember to perform appropriate record selection (“User Personalization”.SETRANGE(“User ID”, USERID) in “On Pre-Data Item” trigger to select the rigth row for current user. After that just open the report [Layout] and drag the field from [Datasets] collection of the [Report Data].
Janis
Here in the data item, just add the field “Profile ID” to the columns.
Programm code need to be added in the C/AL editor - press F9 while cursor is on “User Personalization” data item and copy the following to “on pre-data item” trigger:
“User Personalization”.SETRANGE(“User Personalization”.“User ID”, USERID);
IF (“User Personalization”.FINDSET) THEN BEGIN
END;
END;
is it possible to get the ProfileID just using the Report layout? and without adding any codes?
