hi…
i m new in ax
so pls solve my question…
- Click on grid checkbox then display new form and display this selected record in form??
hi…
i m new in ax
To do that, I’d add a modified method on your grid checkbox, testing your checkbox value, if checked I’d use a menufunction to open the target form, parms are passed with args class as suggested in the following link http://www.axaptapedia.com/Passing_values_between_forms. To open form with code see http://dynamics-ax-live.blogspot.fr/2009/09/how-to-open-form-by-code.html
regards,
Thomas
In modified method of the checkbox just write the below code:
Args args = new args();
args.record(table::find(table.fiedl)); // table is your current form datasource
new MenuFunction(MenuItemDisplayStr(FormtobeOpened),MenuItemType::Display).run(Args);
