Display Production order comment lines?
I’m trying to develop a report to display a daily production order journal.
Production Order
Prod. Order Line <Prod. Order Line>
Capacity Ledger Entry
Prod. Order Comment Line <Prod. Order Comment Line>
Integer DisplayComment
this report request the Posting Date in Capacity Ledger Entry, to show the Output Quantity in that day.
The report works perfectly , but i got a problem when our users request to display production order comment line.
I did the following :
Add 2 global var
CommentLines Text 80 With Dimension 20.
CommentLoop Integer
the following code to catch comments
Prod. Order Comment Line - OnAfterGetRecord()
CommentLoop := CommentLoop +1 ;
CommentLines [CommentLoop] := “Prod. Order Comment Line”.Comment;
and finally in the integer Table :
DisplayComment.SETFILTER(DisplayComment.Number,’%1…%02’,1,CommentLoop);
my problem now is that the reports display all comment !!
how can i fix that problem?
Hi Ali
I guess you have not set the relation between Production Order dataitem and ProdOrderCommentLine on property window of ProdOrderCommentLine, to filter to Production Order.“No.”
Thanks Jay,
My problem was When user specify the the posting date in Capacity Ledger Entry without mention Production Order No. , the reports group Capacity ledger entry with posting date and Production order No. But it displays all comments of all productions orders even it was not in that date.
Now i fixed the issue by adding date filter in ProdOrderCommentLine. it works perfectly
