Can anyone help in returning multiple values in Display method.
If I elaborate this,I Want to display Items for a particular BOMId into the report.
But as display method only returns a single value, so I am getting a single item but I want all the items for a specific BOM Id.
I am using two tables BOM Version & BOM , Also Below is the code working fine if doing in Job but I want to make a method which I can use in SSRS Report .
public static BOM ReturnBOM(ItemId _itemId)
BOMVersion bOMVersion;
BOM bom;
select bom join bOMVersion where bOMVersion.ItemId==_itemId && bOMVersion.Active==true && bOMVersion.BOMId==bom.BOMId;
return bom;
& when I am calling this class using job it is displaying the correct items
static void job(Args _args)
BOM bom;
bom=ClassName::ReturnBOM(“1011-05012”);
while(bom)
print bom.itemNameGrid();
next bom;
pause;
plz help & thanx in Advance
