display marked invoice
Hello All
i want to display marked invoice on report in AX 2012 (create a payment for customer with multiple marked invoice)
i.e.
AR->Journals->PaymentJournal->create a new journal->Lines->Functions->settelment->mark more than one invoices.
display those invoices on report in ax 2012
darshana
In payment journal lines → print → Payment (in that select invoice check mark). this will print the invoices chosen for the settlement.
Hello Kranthi,
I have tried this also but it is not working, the field INVOICE is still empty.
Hello Kranthi,
Please help me…
Have you selected the Invoice check mark in the report dialog? That should show the invoice numbers…
Yes i have select the invoice check mark.
can you post the screen shot/steps done?
Hi Kranthi,
I have done following steps,
but there is no invoice number
Hello Kranthi,
If you have any solution please help me…
Darshana
I can see the invoice details in my environment. Try to debug and see what happens in your case?
It uses \Classes\PaymProposalReportJournal
