I want to disable (Non - Editable or Greyout) a complete Record ( Row ) in a Form by Unchecking a Check BOX in that record.
Please share your ideas…
Thanks in Advance [:)]
Hai Booby,
In form active method of Datasource, based on the check box make it allow edit-false.
eg:
if(ds.checkbox == noyes::yes)
ds.allowedit(false)
i think this would work.
Hi Shon,
Sorry The solution which you given not worked for me.
Any other Ideas
Thanks For your Reply…
Override the modfied method of the field in form by
if(table_ds.checbox == noyes::no)
table_ds.allowedit(false)
else
table_ds.allowedit(true)
let me know the result.
create a new method and write the code
void method1()
if(datasourcename.checbox == noyes::no)
datasource_ds.allowedit(false)
else
datasource_ds.allowedit(true)
Now call this method in your datasource active method and in the checkbox field’s modified method
Best Regards
Hi Shon,
It Seems Working for me ,
But Once i checked that check box the selected row is disabled.
If i want to Uncheck the same Check Box it is not allowing me actually i want this functionality also.
Finally tell me can we disable a complete record by checking the check box except the check box.
Share your Ideas…
Thanks In Advance…[:)]
Yes u can,
It would be like just disable the front fields in that row… i mean each field except ur check box!!
I dont think you will have more fileds in the font end.
Try it!!
Just put a condition and then put a tablename_ds.allowedit(false) in the form level method
tablename_ds.object(fieldid).allowedit(boolean)
do it this way for whichever fields u need to restrict/allow access.
and call it on on active method of the DS.
regds,
narayan Ps
Group all the fields in the fieldgroup except the check box Now use this group in your form
Now in your active & check box’s modified method use the code
if(ttablename.checkbox == NO)
Groupname.enablechilds(false)
else
GroupName.enablechilds(true)
Hi Shon,
If we override the modifed method if once the checkbox is checked we cannot Edit
Any Field in DataSource.
Any How We have to do it in Active method only coz main thing is to disable selected record(i.e Active Record)
exactly bobby but what am suggesting is that instead disabling whole record in any method, disable only the required field which would be possible!
Hi Rajabudden,
Sorry if we apply this condition on Groups
We cant edit the entire group (i.e All Fields and Records inside the group) , But i want to disable only the current selected record
So the sollution is like we have to Override the Actvive() on Datasource then we can get the control on selected record (i.e Active)
Thanks For Sharing your Idea…[:)]
So its working that way??
