Disable and enable
Hi Crate combox throught display method
itemtype
based on tiemtype buttoun will disable and enable how do it any help me
1 . In the button properties make autodeclaration as “yes”
  1. Go to click method of ur button write condition like
if(itemType == ur item type value)
buttonname.enable();
else
buttonname.disable();
ok thank you
Hi jyothi
at packingslip form when was create yesno button
when i will create check box at that time numbersquence generateing if not check not numbersquence generateing how i wil do it
What does it mean?
Can you elaborate?
I was create custinvoicejour form and 3 buttouns SRN And GRN
when i am selected
ItemNo itemtype
Sht100 BOM BUTTON (SRN) " I WANT DISABLE THIS
Sht100 ITEM BUTTON (GRN) " I WANT DISABLE THIS
Note: Itemtype Not in my Table field this called From InventTable throught display Method
Write a method like this and call this in the active method of the form data source
void enableButtons()
SalesCopyAllLines.enabled(InventTable::find(salesLine.ItemId).ItemType == ItemType::BOM);
thank you kranthi
