Hi everybody. I’m trying to write a procedure that inserts several lines into the General Journal. The problem is I can’t get the dimension thing work right. What I’m doing is this:
IF GenJnlLine.INSERT THEN BEGIN
DefaultDim.RESET;
DefaultDim.SETRANGE("Table ID", DATABASE::Vendor);
DefaultDim.SETRANGE("No.", Vendor."No.");
IF DefaultDim.FIND('-') THEN
REPEAT
JnlLineDim.INIT;
JnlLineDim."Table ID" := DATABASE::"Gen. Journal Line";
JnlLineDim."Journal Template Name" := GenJnlLine."Journal Template Name";
JnlLineDim."Journal Batch Name" := GenJnlLine."Journal Batch Name";
JnlLineDim."Journal Line No." := GenJnlLine."Line No.";
JnlLineDim."Dimension Code" := DefaultDim."Dimension Code";
JnlLineDim."Dimension Value Code" := DefaultDim."Dimension Value Code";
JnlLineDim.INSERT;
UNTIL DefaultDim.NEXT = 0;
END;
The procedure inserts the lines all right, and you can see the dimensions attached to each line (Shift + Ctrl +D), but when I post the lines, there’s no dimensions attached to the posted lines. What am I doing wrong? And how can I fix it?
