Does anyone know which table replaced “Dimensions” table from Ax4 in Ax2012 ? And… could someone help out upgrading this method to Ax2012 ? Cant find and do it by myself.
void writeDimensionFile(int _dimCount, str _dimTxt)
Query queryDim;
QueryRun queryRunDim;
queryBuildDataSource queryBuildDSDim;
SysDictEnum SysDictEnum = new SysDictEnum(enumNum(SysDimension));
Dimensions dimensions;
int dimValue;
dimValue = SysDictEnum.index2Value(_dimCount-1);
queryDim = new Query();
queryBuildDSDim = queryDim.addDataSource(tableNum(Dimensions));
queryBuildDSDim.addRange(fieldNum(Dimensions, DimensionCode)).value(SysDictEnum.value2Label(dimValue));
queryRunDim = new QueryRun(queryDim);
while (queryRunDim.next())
dimensions = queryRunDim.get(tableNum(Dimensions));
if (!dimensions.Closed) // R01
info(Dimensions.Num);
info(Dimensions.Description);
