How can get the description of the dimension in a certain record in ledgerjournaltrans? please help me…i need it badly…thanks
Actually it is not clear which description you want but as i understand i give the code,
Dimensions dimensions;
select Description from dimensions where dimensions.Num == ledgerJournalTrans.Dimension[1];
Thanks & Regards,
Britto John Baskar.A
Hi Miss Blue,
Make your Question bit more clear…!
Ok sorry for the confusion… ok this is the detailed problem…
i have created a report called Credit Memo…in AP Module… the report should return the description of dimension [department] of each transaction line. i tried doing this code…
str dim;
select * from dimensions where dimensions.dimensioncode == 0;
dim = dimensions.description
-but it only return the first record in the dimensions table.
please help me…thanks…
but i also get the first
