Hi
I have a customer, who experiences that extra dimension values are inserted to there documents and journals.
It appears it is because NAV reuses the Dimension Set ID, if i.e if the dimension value has already been used.
The result is that i.e Shortcut Dimension 7 is also inserted (automatically) to the document, even though it does not belong to this document.
The NAV version is NAV 2018 build 11.0.20783
