Hi everyone,
can you please help me on dimension set and dimension set rules on how to use it?
Hi everyone,
Can you explain in detail what do you mean by Dimension Set and Dimension Set Rule.
Are you talking about Dimension value / Dimension Combination / Default Dimension Priority?
Im just doing now the setup…i just wanted to know what is the use dimension sets and dimesnion set rules for every transaction. When and how can i use it?..and please do explain the functionalities of every button that we can see on dimension sets and dimension set rules form. Thanks in advance.
You might have wanted to post this in the AX forum rather than NAV [:D]
Dimension sets are a grouping of dimensions for quick use in other areas, whilst the rules allow you to apply rules to enable dimension rules to be set to ledger accounts, journals etc.
I feel it would be best if you read the manual in this area, and then tried to apply this to your scenario, I will not be listing every button and option and purpose as this would be a waste of my time, if you are unsure on a certain aspect then ask away!
Thanks anyway…
