Difference between update and updateWindow ?
Hello. Can anyone tell me what the difference is between the update() and updateWindow() methods? I am using a listbox to display messages on a form, and I want it to update while it carries out a huge method. At the moment, I am using listbox.updateWindow() to achieve this. Should I be using listbox.update() or does it not matter? Thanks, Simon Batchelder
Hi all. According to my supplier, update() is a generic method used with everything in Axapta. UpdateWindow() is specific to certain controls, mainly the ones used for display. From this, it is my understanding that I should use updateWindow() for anything that displays data to the screen, and use update on data objects (tables, grids, views and maps). I would be interested to hear comments on this analysis. Thanks, Simon Batchelder
Hi, I argee. updateWindow() when you want to update some kind of display, fields in a form etc. And update() when you want to update the record in current table(update in database). /Peter Karlsson
But you can also use the ‘refresh’ function to update the changes.
Hi. Could you post more information about the refresh function? Also, when programming a form you can you element.redraw(); to carry out screen refreshes. I think this method would be slower than updateWindow(), as it probably redraws the whole screen, not just part of it. Thoughts and comments? Thanks, Simon Batchelder
Hi Ken,
quote:
Using refresh() function, only datasource can be refreshed. To update the change update() function should be used. Thanks Krishnendu
