Difference between two times
Can anyone help with how to get the difference between two times.
Example: Time in: 6:30
Time out: 18:21
The difference should be 11.51 i.e 11 hours, 51 minutes.
Two options -
  1. Global > timeConsumed
  2. DateTimeUtil > getDifference
Hope this helps.
hi,
In a job its return difference only in seconds.
you can get 11.50 once you saved in table;
Public static real TotalHours()
real Hours;
TimeofDay timein,timeout;
Hours = _timeout- _timein;
if(Hours > 0)
return Hours; // else return hours/3600 – to return 11.50
else
return 86400 + Hours; // else return hours/3600 – to return 11.50
Hope its help you
you can use timeconsumed() – but you have to given input in seconds()
Hello Mr Harish Mohanbabu,
Can you please tell in detail how to use these two options -
Thanks & Regards
Pranav Gupta
Hope this helps -
static void HM_TimeDiff(Args _args)
    FromTime        fromTime;
    ToTime          toTime;
    FromDateTime    fromdt;
    ToDateTime      todt;
    fromTime    = timeNow();
    toTime      = timeNow() + 500;
    //Timeconsumed()
    info(strFmt('Time consumed %1', timeConsumed(fromTime, toTime)));
    fromdt      = DateTimeUtil::newDateTime(systemDateGet(),timeNow());
    todt        = DateTimeUtil::newDateTime(systemDateGet(),timeNow() + 500);
    //DateTimeUtil::getDifference
    info(strFmt('Get difference %1', time2StrHMS(int642int(DateTimeUtil::getDifference(todt, fromdt)))));
In addition to above, the following code can also be used for time difference -
info(strFmt('Time difference %1', time2StrHMS(toTime - fromTime)));
Thank you Mr. Harish Mohanbabu.
