Difference between Restricted and Cascade+Restricted delete actions
what is the difference between cascade+restricted and restricted delete action in AX 2012
Hi ,
pls refer this…
https://amazingax.wordpress.com/2013/01/13/microsoft-dynamics-ax-2012example-of-cascaderestricted-and-cascade-restricted-delete-action-property-for-a-table-relation/
Thank u Gopinath
When your problem get resolved, please mark the helpful reply (replies) as the verified answer (using This helped me below the reply). This makes clear that the thread doesn’t require more attention and it 's also great for other users with the same question, because they can clearly see what helped you.
