Difference between Locations in Warehouse management & Inventory Locations in Inventory Management
Hello All,
I am working on analysis projects on Warehouse Management where i need to gather information on storing the items in the locations. I need to setup the inventory stocking limits based on the Quantity for some items and weight for other items. Can any one please let me know how can i configure the setups for stocking limits based in item weights.
Thank you.
I looks like your need to do some further development, doesn’t look like the default AX comes up with stocking limit based on item weight…
If your Inventory Unit is a weight, say Lbs, wouldn’t that make your stocking limit for that item based on its weight? Your Purchase and Sales Units could be different as long as you setup the unit conversion.
