Hi every one,
what is the difference between runbase,runbasebatch and Sysoperation frame work with examples
Hi every one,
The difference between runbase and runbasebatch is explained here: dynamicsuser.net/…/difference-between-runbase-and-runbasebatch
RunBaseBatch is an extension of RunBase - it adds a support for batch processing.
SysOperation framework is a newer framework replacing RunBase (and its extensions such as RunBaseBatch). It provides better separation of concerns, generation of dialogs from data contracts and quite a few additional features.
I encourage you to read the documentation; you can find more details there.
see this white paper,
www.microsoft.com/…/details.aspx
Thanks for replay martin
What are the methods mainly used
Methods for what?
it means Pack(),Unpack() Methods.
What are you looking for? There is nothing wrong in providing more details on what you need.
You use pack() and unpack() in the RunBase framework (not SysOperation) to serialize the object to a container that can be sent between client and server or saved to database for later execution.
Nevertheless I don’t see what you meant by claiming that “methods mainly used in RunBase and SysOperations frameworks” = “pack and unpack”.
