which one developer toolkit is compatible for nav 5 sp 1?
thanks
thanks
Version 2 - version 3 is Nav 2009.
so… I must download the version 1
is that right?
Sorry didn’t make it clear
Download version 2
Version 3 is for Nav 2009
Navision Developer Toolkit Version 2.00.291 SP3 is the one made for NAV 5.0. The older NDT SP2 version also supports NAV 5 objects.
–Vicky
I already downloaded for version 2
but it was said “There are errors in the text conversion (text no 1973-0 does not exist in the .stx file) Internal Error 47 -1”
what is that mean?
for your information i use .stx file that given default after I install developer tool kit
after I restore devtool.fbk using Dynamic Nav (SQL Server)
and then I open it using devtool.exe
but the error message is Error 52006
and then You Have Not select the database
what is it all about?
