Does anyone have any code that can detect a table locks and return this information in code, i.e. without generating a user visible error. i.e Result =fn(Table) Where fn returns the lock status of a table, Result being Boolean. This is required for Native database, Financials pre 3.7. Background:- We have a site with 120+ users and a large number of stock transactions being enacted by 60+ of them simultaneously. Table locks of item related tables appear to be an inevitability and slow up the system. Currently this is manageable but the plan is to bring a significant number of additional users online. Rather then leaping to SQL and record level locking one option is to detect if a table is locked and not attempt a write to it postponing the transaction to a less busy period. The problem is I understand that the LOCKTABLE function does not return a variable that can be read in code and acted upon. Any suggestions would be appreciated. Regards, Andy
I think you are right. I doubt it is possible, but I know a trick you might be able to use. You can use the fact that a “IF CODEUNIT.RUN(xx) THEN” hides any errors - including lock errors. So if you make a codeunit like this: OnRun() Item.LOCKTABLE(FALSE,FALSE); Item.FIND('-'); And call it like this: OnRun() IF CODEUNIT.RUN(87001) THEN MESSAGE('Ok') ELSE MESSAGE('locked'); However there are two very important things you should be aware of ! First of all does it ALSO send a COMMIT to the database upon success !! Secondly is the lock released due to the commit, so you will need to lock the table again right away with risk of it being locked in between. Use at own risk…
Thanks Peter, We will give it a go. Best regards, Andy
