Dear All,
I would like to ask you about the detail definition of rolled-up Mfg Ovhd Cost that I read from F1-Help windows.
Rolled-up Mfg. Ovhd Cost Field
The Item Table
This field contains the rolled-up material overhead cost of the item. This is a calculation of the total material overhead cost of the components added to the material overhead cost of the parent item.
I’ve tested and tried by using some examples, but I still don’t understand the definition. I also don’t understand (after trial) why the single level mfg ovhd cost calculation of parent item influenced by single-level mfg ovhd cost of subassembly item (single level material cost of parent item) and why the rolled up Mfg ovhd cost is the sum of single level mfg ovhd cost of parent item and sub assembly item, meanwhile single level material cost of parent item = material costs of purchased item + unit cost/standard cost of sub assembly items …???
This really make me doubts and wondering…
Any answers from you I expect so much. tks beforehand.
rgds,
Mark
P.S.
This is the example I’ve tried:
items:
item A-1 = Parent item
prod. BOM A-1 = item A-2 (scrap 10%), A-3 (scrap 10%), A-4 (no scrap)
item A-2, A-3 = raw materialS
Item A-4 = Subassembly
Prod BOM A-4 = item A-5, item A-6
item A-5, item A-6 = Raw materials for A-4 only.
costs:
costing method = standard, LCY.
unit costs item A-2, A-3, A-5, A-6 = 10,000.00 LCY
ovhd rate A-1 and A-4 = 100 LCY
indirect cost % A-1 and A-4 = 10%
routings:
machines qty Routing A-4 = 3 Machines in serial, run time = 10 mins / machine, set up time = 100 mins, 100 mins and 80 mins
machines qty routing A-1 = 4 machines in serial, run time = 20, 10, 10, 7 mins; set up time = 10, 20, 70 and 20 mins
machines costs
direct unit cost all machines = 10 LCY
indirect cost all machines = 10%
ovhd rate all machines = 1
unit costs all machines = 12 LCY
costs excluding set up
the cost calculation results as follows:
item A-4 total cost = 22,139.6 (standard cost);
item A-4 raw material total costs = 20,000
rolled-up mfg ovhd cost = single level mfg ovhd cost = 2,103.6 [(20,000 + 30 + 6) X 10% + 100] -
item A-1 total raw materials cost = 22,000
item A-1 single level material costs = 44,139.6 (22,000 + 22,139.6)
ITEM A-1 single-level mfg ovhd costs = 4,570.36 [(44,139.6 + 470 + 94) x 10% + 100] -
parent item A-1 rolled up mfg ovhd costs = 6,674 (4570.36 + 2103.6)
