Dear All,
I have uploaded data fixed asset with same acquisition date which is December 31st 2013. and also create depreciation journal for each asset as of December 31st 2013.
Actual acquisition date for each asset is different.
With that condition, all asset (with SL dan RB) have same remaining period , if service life 4, then all remaining period 48.
When I want to generate depreciation value in January 2014 for each Asset using depreciation proposal, I found depreciation value in several asset different with value using manual calculation.
After few analysis, I have found a pattern. All Asset who has different depreciation value generated by AX with calculation manual has remaining period less than 12 and using method Reduce Balance.
This remaining period based on actual/real acquisition date asset.
for example acquisition date aset INV-001 is 20-04-2010, using method RB50% (4 years), so remaining period for that asset as of January 2014 is 3.
Any idea what might caused this ?
Thanks & Regards,
Alwin J
