Multiple acquisition has been done for Fixed Asset.
When I run depreciation proposal, system is not taking acquisition dates in to consideration and providing full year depreciation.!!
Can anybody help me which set up check is required to be done in this case to have depreciation for exact number of days from which it is put for use.??
You mean to say that the depreciation is getting calculated for 31 days in May?
If that is the case, check the depreciation run date. System calculates depreciation starting from depreciation run date. So enter 15 May as depreciation run date and recheck the depreciation proposal.
System calculates depreciation depreciation based on service life/depreciation periods as the net impact at the year end is same.
In AX, we don’t have feature of force no. of depreciation days (like in NAV) wherein you can change no. of depreciation days.
There is one alternative, for this period, post a manual voucher depreciating asset with the adjustment value. If you run depreciation proposal next time, it will consider updated NBV. try this on test before doing on production.
If you want to calculate depreciation each day wise, then you need to mark thiland config key in the configuration and you will get days wise depreciation option in depreciation profile, select that and then day wise depreciation will be calculated.
