Deprecated features of d365!
Hello Guys,
I was searching for deprecate features of d365.I found the Summary trial balance, Detailed trial balance, Chart of accounts, Audit trail, Balances, and Balance list reports have been moved, but I could not for the new
**equivalent reports of these. It says replaced by Mananagement reports but I did not found good info about it.**
**Do you know anything about this?I**
GL SSRS reports
Reports that include the following menu items have been removed: Summary trial balance, Detailed trial balance, Chart of accounts, Audit trail, Balances, and Balance list.
Reason for deprecation Financial Microsoft SQL Server Reporting Services (SSRS) reports have been replaced by Management Reporter capabilities and default reports.
Replaced by another feature? Management Reporter (labeled Financial reporting in the current version of Dynamics AX)
Modules affected General ledger
axagain17
Yes Management Reporter is the Finance reporting tool which uses a different cube and its own report designing toolset.
msdn.microsoft.com/…/dn435963.aspx
oh thank you so mxh for reply,there is a something I did not get about it actually ,when I check the d365 I saw summary ltrial Balance-default.I did not get it the default part.What is that mean exactly?what is the difference between ax 12 and d365 version?
I dont know where you are seeing this.
As for the difference between AX2012 and D365O that is a huge question, you have obviously looked at the deprecated features, now you need to start looking at the features that are there.
in here when I create summer trial report I saw these,they have a this default tag.I was asking for the these reports difference from ax 2012 actually not the hole d365 vs ax 2012 actually.
Run one in AX2012 and one in D365O - there will be no one with specific knowledge on a report by report basis. You could post this as a new question and see if there is anyone, but I would suggest simply running the two and looking.
