I had made this and still have the following error while deploying:
ERROR:
System.Web.Services.Protocols.SoapException: Error while loading code module: ‘Microsoft.Dynamics.Framework.Metadata.AX, Version=6.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’. Details: Could not load file or assembly ‘Microsoft.Dynamics.Framework.Metadata.AX, Version=6.0.0.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35’ or one of its dependencies. The system cannot find the file specified.
at Microsoft.ReportingServices.Library.ReportingService2005Impl.CreateReport(String Report, String Parent, Boolean Overwrite, Byte[] Definition, Property[] Properties, Guid batchId, Warning[]& Warnings)
at Microsoft.ReportingServices.WebServer.ReportingService2005.CreateReport(String Report, String Parent, Boolean Overwrite, Byte[] Definition, Property[] Properties, Warning[]& Warnings)
