Deleting TMP files from Temp folder in NAS
We are using NAV 5.0 SP1, and I noticed that the NAS temp directory (location: C:\Documents and Settings\NAS\Local Settings\Temp) has over 2GB. I looked through the directory, and the last time 90% of the files have been modified was back in 2008.
Can I delete those old (file name: Temp.xxx) to make room on my server, or do I need to keep the files there?
Follow this:
  1. Shut down your NAS
  2. Delete all the temp files in that folder
  3. Start NAS
It is definitely secure-
What are those temp files for NAS used for? Will it cause NAV issues if I move or archive the files to another drive?
Also how do you stop the NAS services?
Temporary files are created by a program from time to time for different purposes.
Anyway as temporary files are - as the name says - just temporary it is no problem to remove these files when the program is not running.
To stop the NAS you need to go to your services and stop it.
