Deleting text file using X++ code
I am looking for deleting a txt file inside a folder using X++ code.
Any help!!
Regards
Nitish
WinApi::deleteFile(fileFullName);
thanks for your reply
But i am using a batch to perform this and WINAPI doesnt work in batch :(.
Any other solution.??
Use WinApiServer
You can try the following code, it works in batch:
public server static boolean deleteFile(filename _filename)
FileIOPermission FileIOPerm;
FileIOPerm = new FileIOPermission(_filename,‘w’);
FileIOPerm.Demand();
System.IO.File::Delete(_Filename);
Hope it helps
regards,
Thomas
Thanks Thomas.
It worked.
