Can i delete any records directly from ecoresproduct tbl. Will that cause any problem?
yah you can delete the record if it of no use , but if you are working for any client or have created an instance for that client ,
its better not to delete the record from the table and if you are using for self practice purpose you can delete it and also you can create it too your own records.but dont do it for any client
Alright RG. Thanks for the explanation. Really helpful
