Delete files in Folder using X++ Ax 2012
Hi Friends,
How to delete all the files in particular folder?
I can use WinApi::Deletefile(…) but here i need to give the exact file name. In my scenario, I may have more than one files and in different name. I want to empty the folder.
Please help me to resolve the issue.
Maria
You have two options:
  • either read file names in the folder and delete each one
  • or delete the whole folder and recreate it again
Thanks for the idea. Can you pls give some sample code do that.
static void clearDirectory(Args _args)
System.String[] files;
int filecount;
int i;
if (WinAPI::folderExists(‘C:\Myfolder’))
files = System.IO.Directory::GetFiles(‘C:\Myfolder’);
filecount = files.get_Length();
for(i=0; i < filecount; i++)
System.IO.File::Delete(files.get_Item(i));
