How can be deleted all the special characters contained in a string? I have used (DELCHR(String,’=’,’!’) to delete one char, likewise I need to delete more than one char. Can anyone please share your experience if you had come across with the similar requirement? I would highly appreciate if you can suggest some workaround to manage this issue.
so efficient!
if I need to keep 0,1,2…9, I’ll extend txtCharsToKeep, to become: txtCharsToKeep := ‘ABCDEFGHIJKLMNOPQRSTUVWXYZ0123456789’; am I correct?
It takes the string and removes all the chars you want to keep. Which leaves you with all the chars you want to get rid of. Then it uses that string to remove those chars from the original string. Which finally gives you want you were looking for.
Please how can i delete accents from characters ? for example a customer from France his address in containing characters like (à, â, é, ç…) for example!
any idea please.
