I’m using a Nav version 4 and I have a warehouse setted with “Bin Mandatory”; when I create a production order and I specify location code, automatically the field “Bin Code” is compiled with default bin code defined in item card; in the same way, when create a replenishment line usign planning worksheet, location code e bin code are both compiled with default values.
Now, I’m testing our current db in Nav 2009 but “Bin Code” field, in production order, is never filled.
Can you suggest me if exist a setup which allows to have default Item Bin Code in a production order?
It apears that under the Location Bin Content, you must have BOTH Fixed and Default checked for that item number. If you don’t know where to find this, go to the location card and click the locatin button at the bottem then choose Bins. Highlight that Bin and then click contents. There may be other ways to get there but that is how I did it this time.
If you look at the GetDefaultBin function in WMS Management Codeunit
The following code is added after NAV4.0
Location.GET(LocationCode);
IF NOT Location.“Directed Put-away and Pick” THEN
IF NOT (Location.“Bin Mandatory” AND (NOT Location.“Require Receive”) AND (NOT Location.“Require Shipment”)) THEN
EXIT(FALSE);
As I mentioned in my previous post
Require Receive and Require Shipment should be NO in Location card.
I am als facing the same issue wherein Bin Mandatory, Require Receive and Require Shipment, all are checked. But user does not want to change Require Receive and Require Shipment to NO as there are lot of functionality based on these fields. They don’t want to take risk to disturb their running functionalites with changing these field settings. We are suggesting to comment the standard 2009 R2 code that you mentioned earlier. Do you see any risk or issue commenting this code? Thanks.
