When I am trying to open the debugger window it is giving a error message saying that ‘The X++ debugger work only for users who are in the ‘Microsoft Dynamics AX Debugging Users’ local group of the Windows.’
I have created a new configuration, enabled the checkbox for X++ debugging too. Also I have selected the debug mode to ‘When Breakpoint’ under Tools>Options>Development and also unchecked the Execute in CIL checkbox, Still the issue remained unsolved.
I searched and found out that I have to add my AOS Service Account under the Local Users and Groups inside the ‘Computer Management’. But inside the same I can not find anything like ‘Local Users and Groups’.
I followed your steps and there it is written Administrators inside the Local Security Settings. It means this user (the administrators) is already added in the group. I have checked AOS service account. It is Administrators too.
Now which user do I need to add or should a new one be created.?
But this is what I have been referring to. Its from MSDN.
Thanks Harish,
In the following sections, you determine which AOS service account to debug the RDP class in and add the account to the Microsoft Dynamics AX Debugging Users group. You create a server configuration with debug enabled and then you can add breakpoints in your code.
To determine the AOS service account
From the Start menu, point to All Programs, click Administrative Tools, and then click Services.
In Services, right-click the Microsoft Dynamics AX Object Server service and then click Properties.
In the Properties window, on the Log On tab, the AOS service account is specified in the This account field.
To add the AOS service account to the debug group
From the Start menu, point to All Programs, click Administrative Tools, click Computer Management, and then click Local Users and Groups.
In Local Users and Groups, double-click Groups, right-click Microsoft Dynamics AX Debugging Users and click Add to Group.
In the Properties window, click Add and add the AOS service account to the group.
Restart the machine.
Now how do I add the AX User Account and where exactly.Please help me out with this as I am stuck with this issue for so long now.
