Debugger starting on its own
I have a problem where the Debugger is occasionally appearing when using the POS system. Obviously this is a problem because it’s a store till! We are using Nav 4.03. Has anyone seen this before? I’ve checked to ensure it’s not active, i’ve also tried deleting the zup files. The problem cannot be replicated unfortunately, it just happens every couple of hours sporadically. The problem is on three different machines.
P.
Hi
I have come across this before, someone managed hit the control sequence that starts the debugger. Shift + Ctrl + F11 while typing. We changed their permissions and removed the facility to use the debugger.
Hope this helps.
D
Cheers D, I’ll give it a go and let you know what happens.
