I need to change all date format to DD-MMM-YYYY.I changed in transdate level and modified in region and language settings in server.I can able to see the changes in AX level.Changes is not reflected in SSRS report level.Do I need to do any aditional settings.Is it Possible?
Why do you want to change format like ‘DD-MMM-YYYY’? Sounds quite unusual.
I believe reporting services picks up regional date format setup in the server. You can check this under Control panel → Regional and language options in reporting server. But I don’t think the settings will allow to specify month as ‘MMM’.
Its client requirement.They wants DD-MMM-YYYY date format.I done the same which you mentioned above.As soon as I changed it is reflected in AX level even all tables also.After restarting the service it is reflected in some of the reports.Not in all reports.May I know the root cause? why all the reports are not showing the DD-MMM-YYYY.
