I created three entity after that i deleted two of them after that this error coming.
Getting above issue when i am build my Project in Ax 7.
how i will resolve this issue?
Sumit
Did you follow what the error told you to do? (“You may have to do a full build of the package…”)
Thanks For your reply Martin
This Issue got resolved.
I found that there are two different entity and staging table have same label.After changing the label I putted build & Sync as u said. There are no error now.
Sumit
Hello Sumit,
I am getting this exact same error with my data entities. I have created quite a few of them and at first they all compiled properly. Just from today morning my Project Build is failing and the error message shows something similar to this.
Can you kindly explain in details what exactly you did to resolve this issue?
