Hi guys,
Can someone explain the Axapta object caching that happens and why is there a need to refresh the AOD ? I also want to further understand the propagation of the changes from the cache (client and server) to the AOD.
For example, on a simple setup with one AOS, a client connects and made updates to an object in the AOT. How will the change happen from the client (where changes were made) then down to the server’s AOD and then finally having other client’s being able to see the changes.
