Hello,
i wonder if there is any similar to the .NET Values "System.DateTime.MaxValue/.MinValue in X++?
Thanks in advance,
Frank
Hello,
Thanks in advance,
Frank
Use GETRANGEMIN and GETRANGEMAX functions…
This question is AX - don’t think GETRANGEMIN or GETRANGEMAX works in X++ - that’s NAV code
Topic moved from NAV Developer to AX Developer forum.
Sorry for that…
I just found out that there is a maxdate()-function (result ist 31.12.2154) but - surprise - no mindate()-function (minimum value is 01.01.1901…)
I think a “#define” is the right way…
Greets,
Frank
dateMax() / dateNull()
Thanks - dateMax() returns “31.12.2154”, but dateNull() returns … 0. And this is not a date…
Nope.
See class Global:
static date dateNull()
return 01\01\1900;
Where are you seeing this as zero? What is the problem you’re trying to fix?
Hi mrsalonen,
i just was wondering, if there is a function, that gives me the max/min date in x++. I need this for a time span (which should be nearly “endless”) and in .net i would use "System.DateTime.MaxValue/.MinValue. And i like to use system-functions instead of creating my own constants (or macros…).
This piece of code return 0:
date d = Global::dateNull();
debug::printDebug(d);
But i think i now know why: Minium possible date in AX is 01.01.1901. Every date below is displayed as zero (this is why the function is named dateNull…).
So i have to declare my own macros
Thanks for help,
Frank
date dateMaximum = maxDate();
date dateMinimum = dateNull();
They’re working, really.
