So I ran one of our custom forms through translation - looks OK in the RTC however the date filter fields are not accepting ranges as valid in the RTC…Here’s the field on the classic client form:
As you can see the date range is valid and provides filtering of the data the form is bound to. The field itself is in the table, the field name is “date filter”, Type is Date and fieldclass is FlowFilter. There’s no code in the OnValidate for the field in form.
In the RTC the date range is not valid - it’s throwing this error
Any idea why this is happening?
